Best fuel pump brand...
Ok, looks like I'm going to have to replace my fuel pump... I know this is a NASTY job and I want a pump that's going to be reliable so that this doesn't come around again for a very long time. I know ACDelco is always a good bet... anybody know anything about these others... Airtex, Python Injection, Borg Warner, Carter, or STANDARD as listed on the wonderful Express Auto Parts web page...
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
I assume EFI/TPI setup? Then a WALBRO 190 or 255 LPH pump is all you will ever need. The link to the best prices is: www.members.home.com/syclone/APE/fuelpump.html
Price is $83 for a 190 lph
and $93 for 255 lph. I have had the 255 pump for over a year and it works GREAT and is quiet. HTH's
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
I just had the fuel pump replace on my TBI Camaro.
The mechanic told to me to get a fuel pump for TBI because the TPI pump will not work.
I belive the TBI pump has the fuel pressure in the 13-17 pound range and the TPI pump has fuel pressure in the 40-46 pound range.
The TPI pump may have too much pressure for the TBI injectors.
In any case the TBI AC Delco pump for $35 and new relay for $10 was what I got.
I've been told that the AC Delco pump can supply enough fuel for up to 300hp. If you want to go beyond that maybe something else would be better.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
