Can someone run these casting numbers for me?
Old Jul 27, 2000 | 10:34 AM
90FFBird's Avatar
Front of block K09060ZA
Back of block 10054727
Heads 14102193..... this one is hard to read, it might be 14102183. Thanks, Rob.
Old Jul 27, 2000 | 10:58 AM
Polecat's Avatar
Go to www.mortec.com
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Edelbrock 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane **shrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
[This message has been edited by Polecat (edited July 27, 2000).]
Old Jul 27, 2000 | 02:21 PM
90FFBird's Avatar
For some reason I can't get the link to go through. Is there another one I could try? Thanks, Rob.
Old Jul 27, 2000 | 02:29 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
K09060ZA:
K = St. Catherines, Ontario
0906 = Sept 9th
0ZA (code) = 1980 (year) Marine (application) 427 (CID) 220 (rated HP) L-43 (RPO)
10054727 = N/A
14102193 = 1986-88 350 1.94/1.500 TPI
14102183 = N/A
HTH
Brought to you by www.nastyz28.com
George P. Lara
1984 Z28 High Output
Proud Member of SCFB
V6 T5 For Sale
[This message has been edited by MRZ28HO (edited July 27, 2000).]
Old Jul 27, 2000 | 03:14 PM
90FFBird's Avatar
Interesting, I was led to believe this was a roller block 350" ('90-'91). I'm not sure if I should be glad or disappointed. Does this engine have potential of should I pass it on?
Old Jul 27, 2000 | 07:32 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
10054727 = 350, 86 and up, 2 or 4 bolt main, one piece rear main seal, some made in Canada.
14102193 = as stated above, 87 and up 350
ASE Mechanic/Machinist/Smog Tech
RTKTGTR 1999 NBM T/A, flowmaster,FRA,Pro Kit,BMR STB, polished calipers.
1986 Chevy 3/4 ton pick up,flowmasters,4.10s,
1981 corvette FOR SALE
1995 ZX6R,Yosh,D207s
GO #3
Old Jul 28, 2000 | 07:21 AM
90FFBird's Avatar
Cool, thanks for the help. NOw I have a better idea what to do .
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
ezobens
Aug 19, 2015 10:29 PM
armybyrd
Aug 10, 2015 09:23 PM
