What gears came in stock '82 Z28 posi's?
My brother-in-law just put a mild built 355 in an '82 Z28, and it came with factory posi. Just curious to what they might be. It had the crossfire injection and 700R4 trans.
Thanks in advance!
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Edelbrock 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Thanks in advance!
It was the 305, crossfire injection with 700R4 trans.........
Car: Black '91 Z28
Engine: Bone Stock L98
are you sure it was the 700 r4, anyway if it has the G92 'performance axle' it has 3.23's standard was 2.93, that is for the LU5 motor. I think all the 82's had the THM200c transmission. And i don't think the LG4's came with posi either.
Find the sticker with the RPO codes on it, here's a couple pages you can find a list of them you can cross-reference them to.
http://www.gnttype.org/numbers/rpo.html
https://www.thirdgen.org/cgi-bin/rpo/viewall.pl
Rob_O
[This message has been edited by RobO (edited July 27, 2000).]
Rob_O
I stand corrected, yes it was the 200r.....I thought he said 700r, but I'm sure it has the posi. At full acceleration, it lights both up. Unless the rearend was changed.........hmmmmmmmmmmm
thanks all!
thanks all!
Car: 82 camaro SC
The crossfire engine got the best gears available in 82. 3.23
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
