Weird noise...
Old May 1, 2003 | 01:57 AM
661 RS 91's Avatar
Weird noise...
Hey Everyone,
I have a problem with my car and being a college student, I'm strapped for money, and seeing this board's wealth of knowledge I figured I'd ask you all. My rear end is making a strange "thud" as I call it, when I get on the gas right from a dead stop. I'm guessing it's the axle, but I'm not sure. I was wondering if anyone knew of this being a chronic problem in Thirdgen's and if there is anything I should check before going to a real mechanic?
- JP
Old May 1, 2003 | 02:16 AM
Acidtalons's Avatar
Are you sure the sound is coming from the rear end? Or is it more from the center console?
These cars have a common habit of breaking transmission mounts, which will cause the transmission to hit the underside of the car.
If this is the problem, new mounts usually run $35 and can be fixed with a jack and a socket wrench.
Old May 1, 2003 | 04:47 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Yup get under the car and check the rubber mount at ther rear of the tranny...check for cracking loose rubber.....
Old May 1, 2003 | 11:08 PM
maverick544's Avatar
Tranny mount, had the smae problem. cost $8.99 at autozone, its a pain to get cause theres a cross member right in the way but you can get it even so. Mine was spilt in half when i finally got it out. takes bout ten minutes to do. jack the car up and have a jack under the tranny and simple unbolt and rebolt the new mount.
Old May 2, 2003 | 01:14 AM
JAKEDPLAYA's Avatar
my car does this to...please reply!!!!!!
Old May 2, 2003 | 01:16 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
its most defintely your tranny mount, i broke mine, and it would make a thud, then i put in a poly one, and i havnt broken it yet.
Old May 3, 2003 | 01:23 AM
661 RS 91's Avatar
I just wanted to tell everyone that said, 'tranny mounts' you were right on...took care of the problem today, with a $30 Urethane mount, 45 minutes and the problem's solved. Thanks again for the help.
-JP
Old May 3, 2003 | 01:36 AM
RSstocker's Avatar
hey 661 RS 91 check your private messages
F-body-fan
May 4, 2026 09:42 AM
db057
Jan 10, 2020 08:55 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
BWilcox
Sep 20, 2015 12:19 PM
