How can you tell if a torque converter is "balooned"?
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Can anyone help with this?
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,3" high flow cat with SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner.
Normally, your stall speed will climb higher after it "balloons" because the internal clearances will grow. In extreme cases, when it swells, it will push the nose of the converter (the pump drive) too far into the tranny and eat up the front pump. Unless your car runs hard enough to break into some good times, has a BIG shot of dope, I wouldn't suspect the converters your problem..Unless it's just a REALLY cheaply made converter.
Ragtop Man
Sep 12, 2015 12:23 AM
