Idle after header install
Old May 2, 2003 | 08:54 AM
lowprofile's Avatar
1985 iroc 305 tpi
I just installed headers. I was planning on driving the car with open headers to my exhaust shop for a custom y-Pipe.
Just fired it up, it runs but does not want to idle.
Do you think its a problem with running open headers ?
Or is it probably something else ?
I did remove all the smog stuff prior to header install.
Old May 2, 2003 | 07:32 PM
Dan88IrocZ's Avatar
Did you make sure your O2 sensor is connected?
Old May 2, 2003 | 07:33 PM
Dan88IrocZ's Avatar
Or have you checked your wires? They burn up easy, or you may have them crossed.
Old May 2, 2003 | 07:36 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
anothe ridea
also ive herd that if there isnt enouph back pressure that it will run like crap also im pretty shur eu have to atleast have a little bit to run right.
Old May 3, 2003 | 12:35 AM
lowprofile's Avatar
I installed new plug wires, ran them properly, o2 is hooked up. I am going to install an old crappy y-pipe and see if that helps.
there was also a lot of backfireing. gas smell was really strong
thanks for your help
specialized
Jun 18, 2022 09:26 AM
Wesly_66
Aug 26, 2015 09:55 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
drathaar907
Aug 6, 2015 04:20 PM
