Cam/Intake Swap parts needed Questions
Car: A Camaro
Engine: Weak
Transmission: Weaker
As far as a cam/intake swap goes here are the parts that I've ordered:
Intake Gaskets
Air tool to keep valves from falling into the bore
Valve Cover Gaskets
Valve Springs (Z28 springs from powerhouse)
Timing Chain
Timing Cover Gasket
Cam Break in Oil
Oil Pan gasket
Thermostat Housing Gasket
RTV, anti-freeze, oil, oil filters and distilled wate
Intake
Cam
I was wondering if I needed any of the following:
A Distributor Gear
Locks/Retainers
Shims for the springs
Valve Seals
New Timing Cover
Lifters
I'm pretty new at this, it's a used LT1 cam that's going into my 305 and we're moving the condensor and radiator and front clip out of the way and putting her in the front. Any suggestions on parts to get?
Tony
Intake Gaskets
Valve Cover Gaskets
Timing Chain
Timing Cover Gasket
Cam Break in Oil
Oil Pan gasket
Intake
Cam
A Distributor Gear
Locks/Retainers
Valve Seals
New Timing Cover
Lifters
Tony
Car: 4
Engine: 6
Transmission: 5
Locks/Retainers
Valve Seals
Valve Seals
