What amount air do i put in my tires?
Old Jul 28, 2000 | 12:16 PM
KamaroZ350's Avatar
Car: 2008 Jeep Wrangler Unlimited
I have these crapy Sumitomo tires i was sukerd into getting. They lose air alot, and i know the weight or PSI or whatever is wayyyy off. Im going to put to correct amount in today as soon as i finish washing it. So how much goes int he front and back tires?
1991 Z28 Camaro L98
5.7 T.P.I. (350)
http://www.bright.net/~rwig/BandetZ28.jpg
http://www.bright.net/~rwig/BandetZ28-2.jpg
Old Jul 28, 2000 | 12:24 PM
98_1LE's Avatar
If they are losing air they have a leak and changing the amount of air won't help. Get the leak fixed and I run 34 psi front and 30 rear. Check your tires sidewall for recomendations.
87 Formula 350 14.81@91.64
98 Z28 1LE 13.15@107.59
Old Jul 28, 2000 | 03:05 PM
KamaroZ350's Avatar
Thanks, their is a leak somewhere in the rear drivers side tire, the others are ok now, but very often ill go outside and my car will be parked in the garage w/ a tire very low on air, then ill have to go and get it patched up.
1991 Z28 Camaro L98
5.7 T.P.I. (350)
Old Jul 28, 2000 | 10:51 PM
steve8586iroc's Avatar
Kamaro,fill a spray bottle with some soapy water and spray the tire very generously over the treaded area and then around the sidewalls or visa versa, watch for tiny air bubbles, when spotted you have found your leak. My guess is that the bead area of the rim needs to be cleaned with a wire brush. This happens a lot when you replace your tires over the years without cleaning the rims. I don't think I've ever seen a tire store do this unless it is requested by you. Hope this helps.
Steve
eightsixseven
Dec 16, 2024 01:50 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
