I need a real quick answer... AFPR
It has been so long since I have done this I forget the proper way. I know I need to crank my fuel pressure up. I have the AFPR, but I forget how to do it properly. Can someone please give me precise instructions. Thanks my trans am is waiting.
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank, bearings, rings, and magnafluxed rods. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,SVO 24# injectors,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
Kills:
It is a TPI system, isnt it? Just look under the back of the plenum where the regulator is. To increase the pressure, screw the screw in. To decrease it, back the screw out.
86 Trans Am WS6: The muscle car lives
KF,
Connect the test gauge to the Schrader valve on the right (passenger) fuel rail. Start the engine and disconnect the vacuum line to the fuel pressure regulator. Monitor fuel pressure on the gauge while turning the adjstment screw on the regulator. The factory setting should be arount 47PSIG +/- 3PSIG. You may want to increase as much as 4-5 PSI even though you have the larger injectors. Your oxygen sensor readings at WOT will be your best indicator of correct pressure at full load.
Later,
Vader
"Some Body...Someone"
Later,
Vader
Okay. Question for Vader. What tool exactly do you use to turn the screw while the test guage is still attached? I havent figured out how to do this yet. Pliers in no way work, and I have a wrench that works, but I cant get enough travel on it to move the screw while the test guage is attached.
I have to keep putting the thing on and removing it, and I'm uncomfortable with the amounts of gasoline I end up dripping on the intake manifold.
[This message has been edited by WillDC7 (edited July 28, 2000).]
