fuel pressure check
Old Jul 28, 2000 | 09:42 PM
pianiy's Avatar
fuel pressure check
Ok, I'm going to do my own fuel pressure check tonight or tomorrow and I haven't done this before. I've got a 305 TBI L03 and it surges when I start it up cold then evens out after 5-10 mins but when you put a load on it in gear it bogs down and sometimes stalls... I've checked for vacuum leaks and changed the fuel filter. The last time I had this type of problem was on the '87 and it was the fuel pump. SO what kind of fittings do I need for this to work? Any other advice? Thanks.
'91 Firebird
305/TBI/700R4/T-tops all stock
K&N Air Filter
Pioneer DEH-P8200R
Pioneer 6x9's
Kenwood 8" Tube
'87 Firebird
2.8L/MPFI/700R4/220K Miles on its original, never been rebuilt engine!
Car being parted and sold, just ask what I have.
Old Jul 28, 2000 | 10:55 PM
Vader's Avatar
pianiy,
There is no fuel pressure test fitrting on most TBI engines, so you'll need to adapt a Schrader fitting in the fuel line between the filter and TBI unit. Mr. GM Tech tells me there's a nifty fuel filter/adapter setup made just for this purpose - you may want to check into that before you start cutting any fuel lines.
Later,
Vader
"Some Body...Someone"
Old Jul 28, 2000 | 11:03 PM
pianiy's Avatar
Vader,
What do you mean by "fuel filter/adapter setup"? Checking the fuel pressure at the filter you mean? Where could I find something like this?
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
