torq specs on rr's
Old May 4, 2003 | 12:46 PM
f0rmula350's Avatar
torq specs on rr's
wahts the torq specs on roller rockers?
Old May 4, 2003 | 06:58 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Unless your talking about a 3800 Series II V6, or a 3100/3400 engine, there is NO torque spec for the roller rockers. There is, however, a lash procedure for tightening them that you will need to follow.
Old May 6, 2003 | 03:31 PM
f0rmula350's Avatar
and that is
Old May 6, 2003 | 03:42 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Originally posted by f0rmula350
and that is
...not a tpi specific question, so i'm moving this to general tech.
BTW, setting lash on a SBC has been covered numerous times in the past, a search might be a good idea. Always is when the procedure takes longer to describe then it does to complete.
Old May 6, 2003 | 04:25 PM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
spin the pushrod with your finger, tighten the rocker down until the pushrod doesn't spin easily anymore, then 1/2 turn more for each rocker.
Also, make sure the valve is closed on the rocker you're adjusting or you'll have to do it again. Easiest(for me at least) to do each cylinder's rockers at TDC just to be sure the valves are closed.
-Matt
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
angel2794
Sep 8, 2015 06:22 PM
