Do i have everything?
Old May 5, 2003 | 03:37 PM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
Im going to be doing my cam swap at school once i get my springs in the mail and wanted to know if i need anything else or if anyone has any tips for the swap
zz4 cam
LT4 valve springs
LT4 valve spring caps
Intake gasket
valve cover gaskets
im sure theres more but i still dont know alot about valve train
Old May 5, 2003 | 06:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What heads? What engine?
"Spring caps"? If by that you mean retainers and keepers, yes, you need those (you should be able to re-use keepers, if they are made for the same angle as the retainers and aren't damaged).
Also need front cover gasket and water pump mount gaskets.
Until we know what engine you're talking about, hard to know if you'll need anything else.
Old May 5, 2003 | 06:35 PM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
its a 87 305TPI
thx
Old May 5, 2003 | 10:19 PM
Vader's Avatar
Those springs may be about 0.080" too large to fit your heads. They fit some stock spring seats, and they don't fit others. Don't be completely surprized if you have a snug fit.
Another item to check will be the rocker studs and nuts for wear and locking ability. You don't want the rocker nuts backing off over the slightly stiffer springs and more aggressive cam ramps. Take a close look at the rockers for wear, and watch the slot and spring clearance when you reinstall them.
The ZZ4 cam profile isn't so radical that you'll necessarily need to change push rods, but you should check the clearances and geometry just to be sure.
Of course, you should install a new timing chain and sprockets. Might want to take a close look at the lifter bodies and rollers for wear.
While the water pump is off, you might as well scrutinize the bearing and seal, just so you don't have problems with it later.
Also, you'll need the gasket set, coolant, oil, oil filter, RTV gasket sealant, antiseize compound, thread sealer, and other normal shop supplies.
