hard wiring t/c
Old Jul 29, 2000 | 02:00 AM
hookin88formula's Avatar
hard wiring t/c
i went to the track the other night and a buddy of mine showed me a neat trick on how to hard wire my torque converter. actually all we did was take a piece of wire and stick it in the a and f terminals under the drivers side dash. but he told me that i could make a switch to turn in on and off so i dont have to keep pulling the wire out after every run. how is this possible anyone else ever done this? do i have to ground it or hwo does it work please let me know thanks.
1988 firebird formula350tpi msd 6al box blaster 3 coil accel 8.8 wires flowmaster cat back pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges b&m mega console shifter
Old Jul 29, 2000 | 02:12 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
All that piece of wire does is connect the TCC solenoid pin on the ALDL connector to the ground. The TCC circuit runs from the gauges fuse through the brake pedal switch, into the solenoid, and into the computer, or to a vacuum switch if you have a non-computer controlled car. In either case, the computer or switch interrupts the ground to lock and unlock the TCC. The pin on the ALDL connector is wired "between" the solenoid and the computer.
Old Jul 29, 2000 | 05:11 AM
Ski89Z28's Avatar
Apeiron or anyone who can answer this.
Do you know how much current goes thru the wire? Cause I would like to know what size wire to use and how heavy of a switch to use also.
Thanks.
Old Jul 29, 2000 | 10:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's a couple of amps at most. #18 wire and a normal switch should do fine. The problem is putting it somewhere that is convenient to use while driving.
Those of you who ever drove one of the Vettes with the "4+3" POS will remember one possibel solution.
Old Jul 29, 2000 | 12:07 PM
yes but now that i know this will work.. how do i wire it up? do i just take a toggle switch and wire it into the a & f terminals or do i have to ground it what is it i have to do? thanks
Old Jul 29, 2000 | 02:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The F terminal is the one connected to the TCC solenoid, and the A terminal is just a ground. You can just splice into the wires going to the A and F terminals if you want. It might be easier to splice to the F terminal wire, and then connect the other terminal of your switch to a convenient ground near your mounting point.
[This message has been edited by Apeiron (edited July 29, 2000).]
Caspar
Jun 19, 2016 11:19 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
db057
Aug 22, 2015 08:17 PM
apie2546
Aug 8, 2015 07:12 AM
