Backspacing Question
Old May 5, 2003 | 07:53 PM
88 IROC BOB's Avatar
I have an 88 IROC with the 16" factory wheels. I want to find a set of 15" rims to put on BFG DR's 275/50/15 for track use only.I don't even care if the wheels are just plain steel wheels.
What should I look for in a rim as far as backspacing? Will an 8" wide rim be alright?
Bob
Old May 5, 2003 | 08:34 PM
Boxeat2469's Avatar
I have Nitto 275/50/15 drag radials on a set of 15x8 rims. I went 15x8 all the way around with 4.75" backspace on the fronts and 5.25" on the rears. If I had it to do over again, I would have went 5" on the rear. The drag radials don't rub at all, they fit perfect. But when I put the 28" tall 10.5" wide slicks on, I had to use 1/4" spacers, otherwise the sidewalls rubbed the inside of the wheel wells just a touch.
Old May 7, 2003 | 05:09 AM
What about 15X10's with 4.75" of backspacing? Will they stick out too much?
Bob
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
