porting 6X pontiac heads
Old May 7, 2003 | 08:26 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
i'm building a 455 pontiac. i have some 6X heads and i want to clean them up some. i know i need to trim the valve guide up some and round the short side radius some but could you tell me more exactly what to do and how much to take off? heres a pic of the intake port, on the short radius how much should i take off? should i just take enough off to round it off?
Attached Thumbnails porting 6X pontiac heads-i6x-head-int-low
Old May 7, 2003 | 08:30 PM
TheViper's Avatar
Car: '84 Z28
my second question is should i take any off inside of the bowl area just below the valve seat? it looks pretty small. i read in the standard abrasives thing that it sould be about 85% of the valve seat, it looks like mine is more like 75% or less.
Attached Thumbnails porting 6X pontiac heads-6x-head-int-exh
Old May 7, 2003 | 08:32 PM
TheViper's Avatar
Car: '84 Z28
on the valve guide how much should i take it down?
Attached Thumbnails porting 6X pontiac heads-6x-head-int-valve
Old May 7, 2003 | 08:33 PM
TheViper's Avatar
Car: '84 Z28
on the exhaust should i remove that lip on the short radius and open it up a little all the way around?
Old May 7, 2003 | 10:52 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The short answer is YES and AS MUCH AS YOU DARE.
You cannot get this head too big for a 455. Go with the biggest valves that will fit too. Get the garden hose and squirt the water stream in to the ports. You'll get a good visualization of the high flow paths. Airflow does not like sharp edges or abrupt changes in direction.
69GTOby
Apr 18, 2016 02:34 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
ericjon262
Sep 11, 2015 06:07 PM
toronto formula
Sep 10, 2015 07:31 AM
hdis2002
Sep 8, 2015 02:52 PM
