225/50/15 too small?
Old May 8, 2003 | 10:01 PM
rumpilstiltskin's Avatar
Are these tires too small? What size/brand tires are you guys out there with the stock 15" rims running? I wanted something wider/lower profile than the stock 235/60/15. Will these tires do that? Any input appreciated.
Old May 9, 2003 | 12:40 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
A 225 is narrower than a 235. Im running 235/60/15s BFGs on my other Firebird, they look okay for 15s. Low profile tires on 15in. rims will look strange in my opinion, there would be too much gap between the tire and fender.
Old May 9, 2003 | 04:50 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
You can see 48 replies im my thread "Best tires for V6" into V6 forum (last post 01-03-2003).
Denis V.
Old May 9, 2003 | 07:01 PM
Vader's Avatar
Rumple,
Are you using factory (7" wide) wheels? The diameter of the 225/50s will be about 2¼" too short in diameter, and throw your speedometer/odometer off by about 9½%.
One option with 15" wheels would be 255/55-15, which would be a stretch on 7" wheels. If you have 8" wheels, they should fit without too much crowning.
You can download my Excell spreadsheet calculator to determine correct O.D. sizes of various tires (along with some other engine math):
Engine Calculator.xls
Old May 10, 2003 | 04:56 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I'd go with at least 225/60/15s... they are a little taller and are very close to the factory height. If they are too much different, your speedo will be inaccurate.
Old May 10, 2003 | 06:48 PM
my speedo already reads about 10 below what it should (40 mph) at 50. I checked out these tires at the store and they are approximatly the same width if not wider than the factory 235/60/15, due to the 50 vs. 60 in sidewall height to tread width ratio. I have the stock 15's, so would 245/55/15's be a good choice? I would like to get at least a little bit smaller diameter tire so my car doesnt look like its sitting on balloons like it does with the stock 235/60/15's. Does anybody make 245/55/15's? I figured if the 255's are going to be a strech i might as well just take it down one step. thanks
Old May 11, 2003 | 12:09 AM
Air_Adam's Avatar
You'll REALLY want to go with an 8" wide wheel for anyting bigger than a 235. Period.
Old May 11, 2003 | 01:22 AM
82Z28NAZ
Guest
Posts: n/a
stock tire size for 15" rims is 215/65/R15
I was running 255/50/R15's on the back and 225/60/R15's on the front. I just got another set of 225/60/R15's for the back and the car handles much better. It also might be noteworthy that the set of tires that came off the back had a bad bad crown-wear pattern.
Old May 11, 2003 | 10:16 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
I have 235/60/15s on the front and 255/60/15 on the rear on stock 7 inch Z28 rims. I used to have 245/60s on the rear and I like their look better and are just fine on the 7 inch wheel.
My car had 225/50s on the front when I got it and it looked absolutely ridiculous.
Old May 12, 2003 | 03:45 PM
Pepsicola's Avatar
Engine: 305 TBI
Transmission: 5 spd
Axle/Gears: 10 bolt w/eaton posi 3.73
I'm running that same setup on stock firebird rims. IMO it looks real nice. I got the BFG Radial TA's.
Old May 12, 2003 | 03:47 PM
82Z28NAZ
Guest
Posts: n/a
can someone take a picture of their wheels and post them?
Old May 12, 2003 | 03:49 PM
Pepsicola's Avatar
Engine: 305 TBI
Transmission: 5 spd
here you go...
Attached Thumbnails 225/50/15 too small?-ta_side_stock_rims.jpg
Old May 12, 2003 | 04:00 PM
82Z28NAZ
Guest
Posts: n/a
ahhh yes...
thanks for the pic
doesn't that make it hard to rotate the tires?
Old May 12, 2003 | 04:17 PM
Pepsicola's Avatar
Engine: 305 TBI
Transmission: 5 spd
Not really, I can still do burnouts real easy. I used to have 235/60/15 all the way around and could scratch the tires going into 4th gear, but can only do that into second gear now.
Old May 12, 2003 | 04:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I have the 235/60/15 all around. I'm not racing, and not canyon carving, and I'm too old for anything more than an occasional screech from the light. I'm also a tight @ss! I got Yokohama Avid S/T from tirerack.com for about $230 shipped (all 4) - and they work for me.
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Oct 5, 2015 06:23 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
