help needed fast, wont start
Old May 10, 2003 | 05:40 PM
Adam62083's Avatar
I changed my thermostat today. When I was doiung it, I disconnected the wire to the alternator that attaches with a clip. After I finished putting in the thermostat i forgot to put it back in when I tried to start the car. It tried to start and died immediately. I put it back in, and it wont start now.
Also, I cant read codes now. I dont know what to do, and I have to go to work in 15 minutes.
Any ideas? I went though all the ecm and crank circuit fuses in the fuse box and they were fine. Are there fuses around the block I should check?
Thanks,
Adam
Old May 10, 2003 | 05:42 PM
Adam62083's Avatar
By the way, the starter tries to start the motor and it turns it over and over and over, i just dont get any ignition.
So the starter is fine.
Old May 10, 2003 | 10:03 PM
chrisj678's Avatar
Is the battery dead? Try jumping it if so.
Old May 10, 2003 | 10:45 PM
CamaroRS385hp's Avatar
Car: 1987 Iroc-Z28
Transmission: auto
if the battery was dead the car wouldn't even try to crank....it'd just be a fast clicking sound, but wouldn't try to turn over at all
Old May 11, 2003 | 01:00 PM
Vader's Avatar
What year/engine do you have (there were differences)?
Old May 11, 2003 | 09:08 PM
sixt8bird's Avatar
Try squirting some gas down the Throttle body and turn it over. I have the same problem once in a while and am sick of it but this is a temporary solution to a on going problem. Mine fires up instantly this way but will just keep turning over otherwise. Mine is a 1989 GTA L98 TPI. Why did they eliminate the cold start injector in 1988?
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Fast355
Dec 2, 2016 06:33 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
