Autoxray..spark timing, Is displayed timing.. total timing?
Old Jul 25, 2000 | 09:24 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
IM trying to figure out my total timing at WOT with An Autoxray I just bought. I dont know if I understand it correctly. Can anyone help? IM getting 25* on the scanner at WOT, It retards from about 40* while cruising. I know A smallblock needs 32-40* of timing at WOT for good power. SO 25* is not good, IM also getting 8*-10* of retard under WOT. Is this normal? Is this why my IM only getting 25* at WOT?
Do you add the intail timing to the scan timing number to get the total? How do you figure your total from this?
Mike
Black 90 IROC, L98, A4, 323 gear, Edelbrock TES, 3" Dynomax catback exhaust, Performance Resource chip, Accell LT runners, MSD6A ign, ported plenum, cut airbox, Airfoil, K/Ns, AFPR, AGR 12.1 box, soon to have 406 sb.
Old Jul 25, 2000 | 09:37 PM
DownUnderIROC's Avatar
The scanner is showing you ECM timing and knock sensor retard. To figure out the total timing:
Initial Timing + ECM Timing - KS Retard = Total Timing.
1987 Chevy Camaro IROC-Z
1998 Ford Falcon XR8
My IROC-Z in Sydney, Australia.
Thunder Down Under home page.
Old Jul 25, 2000 | 10:01 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Thanks DUI...Initial is the Number of Degrees i have at the balancer right? Not what the computer is showing at idle in drive. I have it set at 6* on the balancer, and the computer is showing 16-18* in drive at idle.
So my total would be 6+25=31*
Old Jul 25, 2000 | 10:27 PM
blowen90ta's Avatar
i dont think thats right i think the computer takes into account for what it thinks the factory timing is so only add if you have advanced past the factory setting. just my .o2
pete
1990 Trans Am,350 TPI(L98),WS6suspension ,bridgestone RE71's /245/45/zr16
paxton supercharger, alston sfc's,msd 6AL-BTM,
8.5 superconductor wires SLP 1-3/4 headers,duel cats,3"slp exaust, lakewood LCA's,T.B.Bypass
160 degree stat,alum driveshaft,fiberglass wing, secret mods
"if you cant win fair CHEAT"
Old Jul 25, 2000 | 10:36 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
No. The computer has no idea what the crankshaft base timing is. It is only showing what it is giving you on top of whatever the base timing is.
To see the knock effect, look at the data for the knock retard. You should be able to watch the number of degrees of retard the computer is giving you every time you encounter knock. I can't remember exactly which channel on the Xray it is... one of the channels shows just the number of times the computer has detected knock since some time in the past, while the other channel shows the exact amount of retard present at any moment (which should obviously read zero while just cruising along).
Old Jul 25, 2000 | 10:43 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
IM getting 8-10* of knock retard at WOT. So...with 6* of base Timing and 25* showing on the scanner I have 31*? Or... is 25* the total?
Old Jul 31, 2000 | 12:26 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Also..I noticed monitoring the (EGR duty cycle)The percentage never changes. I have a P.R. chip, could they have deleted the EGR function? Or is my soleniod not working? It doesnt seem to be doing anything.
The Auto-xray Manual says that the EGR duty cycle is...The amount of time that the soleniod in the exhaust gas recirculation valve has been cycled ON. The soleniod is cycled...to quickly modulate the valve and control its air flow.
Range: 0 to 100%.
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
TheExaminer
Aug 19, 2015 10:07 PM
