Need engine code Please help!
Old May 12, 2003 | 10:34 AM
Athila's Avatar
Car: 1987 IROC-Z Convertible
Engine: 5.7 TPI
Transmission: WB performance auto
Hi! I have an 87 Iroc wich has a 1992 350 5.7L TPI engine. As you can see i have no way to know the vin for the 92 engine. I need to find out if anyone knows what was the engine code for this engine, was it E or F or 7 ?
Old May 12, 2003 | 10:44 AM
3rdgenstm's Avatar
Car: ‘92 Z28
The VIN code is an "8". You can find the VIN on the engine. There is a pad on the right hand side of the engine block located in front of the head. The VIN will be stamped there. You might have to clean it off to see it and move the heater control garbage.
Old May 12, 2003 | 12:09 PM
Athila's Avatar
Engine: 5.7 TPI
Thank You! I'll look for it.
Old May 13, 2003 | 10:28 AM
Vader's Avatar
You may have to clean a little grime and paint, but it should be here:
Old May 13, 2003 | 10:41 AM
Athila's Avatar
Engine: 5.7 TPI
got it, it's an 8. Thanks everyone!
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
