how do i get the total timing down?
Old May 12, 2003 | 10:40 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
I've been trying to get the curve right on the distributer all morning, and i can't seem to get the total down no matter what combination of springs i use.
As of right now, the timing is set at 12* initial, and 44* total. I only want like 36*.
How can i accomplish this?
Eric
Old May 12, 2003 | 10:45 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Disconnect the vacuum advance, and check it again.
I have never heard of a dist with 36° of mechanical advance. (Not to say that it couldn't happen, but...) However, 24° of mechanical, plus 12° of vacuum, is just about perfect for most performance-built engines.
Old May 12, 2003 | 10:55 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
just disconnected and retested. With no vacuum i still get 12* initial, however now i only get 32* total...
What now?
Old May 12, 2003 | 11:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like maybe you could actually use a bit more mechanical then, not less. Most of the time, SBCs run best with about 36° "total" static + mechanical, before vacuum advance is added. You have 12° of vacuum advance which is a good starting point in tuning for best cruise manners and gas mileage.
Old May 12, 2003 | 11:17 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
i see. thanks for the help
Eric
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
bellez77
Sep 5, 2015 08:39 PM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
