Poll: What headgaskets ?
Old Jul 31, 2000 | 07:21 PM
Blade's Avatar
I'm about to change my headgaskets tonite, in my quest to find the oil burning problem happening in cylinder #6. The FelPros that come with the head gasket "kit" dont look too "high performance" to me, so I wanted to ask you guys which gaskets you use and what would be recommended for my 92 L98 engine... ? Thanx in advance.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Jul 31, 2000 | 07:26 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Fel-pros are pretty good. I use them when I do headgaskets when I am not at work. When I am at work, I use (what do you think I use!) Later.
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
About Me
Old Jul 31, 2000 | 07:31 PM
Blade's Avatar
Lemme take a wild guess here... Toyota head gaskets ? LOL j/k
That's cool... I guess I'll just buy ANOTHER set of FelPro's.
See... I call Spartan engines and asked what to do about this. They sweared up and down it's not their shortblock that has bad rings and it MUST be my heads, valve seals or intake gaskets. I told em I replaced the gaskets twice but they said I should check the heads before I ask em to check out the shortblock.
92 Z28 L98 350
Old Jul 31, 2000 | 07:41 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
How did you know I put toyota gaskets on Buicks?!?!
Anyway, I hope you figure it out. Have you replaced the valve stem seals? If it comes down to it, are they going to reimburse you for all the head gasket jobs you have done if they do find out it was there shortblock?
Some people do some crazy stuff, like one time, I opened a brand new rotor out of an unopened box, and whoever put it in the box took a chisel and gouged the inner bearing race and engraved F**K YOU on the rotor surface. It came right out if the box like that! Must have been somebodies last day at the plant! Not that somebody intentionaly misassembled your engine, just thought I would throw that in there.
Savannah, GA
'97 Bonneville SSE
About Me
Old Jul 31, 2000 | 07:47 PM
Blade's Avatar
Well the machine shop that did my heads told me about the bad reputation spartan engine has (got the engine trough Checker auto parts). One of the guys quit them because their standards for assembly were too low and they didnt check clearances before assembling engines. I find that hard to believe since I dont think they're in the business of losing money (they have a pretty good warranty, so if that were true they'd have to replace every other engine that came out of there).
I'm gonna do a leak down test tonite, and figure out exactly what's going on in cylinder #6. Oil getting past the rings, trough the intake gaskets or trough the valve seals...
92 Z28 L98 350
Old Jul 31, 2000 | 07:50 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Cool, let us know.
Savannah, GA
'97 Bonneville SSE
About Me
quadgoat
May 2, 2004 12:15 PM
N8MAN1068
Dec 29, 2003 02:26 PM
mdnite92Z28
Jul 31, 2003 09:57 AM
88NOSTA
May 18, 2003 08:34 AM
Bort62
Mar 17, 2003 12:03 AM
