Too hot in car
Old May 13, 2003 | 09:24 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
Too hot in car
Why is it that every time I go to drive my car, it starts getting hot in there after about 10-15 minutes after driving? My heater is off and still gets hot in there.
86 trans am
Old May 13, 2003 | 10:06 PM
Vader's Avatar
Warrior,
The '86 models did not have a hot water control valve for the heater core, so hot coolant flows through the core at all times. While this is great for keeping the core from clogging or rotting out prematurely, it can admit hot air into the passenger compartment if the air control dampers in the HVAC system are not adjusted properly. The Bowden cable that controls the air temperature door position can slip, stretch, and bend over time, requiring adjustment to keep the door fully closed in the COOL position.
Old May 13, 2003 | 10:16 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Searches for question vader cant answer and i cant find one lol
the man knows , plain and simple lol
vader: u get my pm about memorial day weekend gathering?
later
Jeremy
Old May 14, 2003 | 02:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You can find the temperature door if you remove your passenger side hush panel- the black panel above the passenger's feet. You'll see the cable and lever. Make sure nothing's snapped, and that the door is all the way to "cold".
Asides from that, make sure the weatherstrip at the back of your hood, against the cowl, is in good shape. If the temp door is at "cold", the hood's the only place you can get hot air from.
Old May 14, 2003 | 02:53 PM
warrior_91's Avatar
Car: 86 T/A
Does it have anything to maybe do with the little black chin spoiler that mounts underneath the radiator. My car doesn't have that spoiler and its critical for cooling isn't? The car doesnt have any grills so all the air has to be collected and sent up through the radiator by that spoiler.
Old May 14, 2003 | 10:17 PM
Vader's Avatar
If you are missing the lower air deflector set, the engine will tend to run hotter. However, non of that heat should enter tehpassenger compartment unless the sir door is leaking, or the cowl air seal is missing or damaged (Good call, Tom!).
Regardless, I'd suggest repairing or replacing the air deflector before the real heat of summer arrives.
Old May 15, 2003 | 09:06 PM
Duke901's Avatar
Car: 89 Formula
what year did they start putting in the hot water control valve
TheExaminer
Aug 26, 2015 04:59 PM
jackhammer
Aug 15, 2015 10:04 PM
mustangman65_79
Aug 11, 2015 03:17 PM
86Base
Aug 8, 2015 01:34 PM
