Loss of umph
Old May 13, 2003 | 09:50 PM
guza's Avatar
Car: 1985 Berlinetta
Engine: 305 4BBL
Loss of umph
I have an 85 LG4, Quadrajet. Today I started having a loss of power. If I take off slowly, the car will reach about 30MPH, and that is it. If I try to get on it at all It acts like it is chugging. I hear the secondaries opening but no power. Almost like my nearly new exhaust was plugged.
I tried this in park and I got the same result. However, the top butterflies of the secondaries would not open. Tried 2 different carbs with the same result. I sprayed some carb cleaner around the carb to see if it was sucking air. No luck! I changed the gasket anyway.
I think this may be a vacuum leak. I was hearing a whistle but could not find where it was coming from. Would a bad EGR have this affect. Im going to try changing the EGR gasket tomorrow.
Any help is appreciated.
Joe
Old May 14, 2003 | 02:56 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
clogged cat/
Old May 14, 2003 | 06:46 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
you do anything recently to the car like spark plugs or wires? make sure the firing order is right. when i had a wire on backwards id top out at 30 too
Old May 14, 2003 | 07:39 AM
guza's Avatar
Engine: 305 4BBL
No, I haven't changed any of that lately. The engine was rebuilt in December. Most of that stuff was new then. I had to replace the cat for emissions. Do you think that could go out or clog in 5 months?
The whistle I heard may have been exhaust strying to come back through the AIR system if the cat is clogged right?
Old May 14, 2003 | 08:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Clogged cat
Yes that can make it whistle
Old May 14, 2003 | 06:29 PM
guza's Avatar
Engine: 305 4BBL
Thanks again
Well you guys have solved it again. The Cat was melted and clogged. :hail:
I ran for about 3 months with a bad ECM. Now that is changed, I hope I don't have these melt downs again.
RedLeader289
May 28, 2019 01:47 PM
Elephantismo
Feb 13, 2019 12:51 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
3.8TransAM
Sep 27, 2015 08:37 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
