Head Volumn Size
Old Jul 31, 2000 | 11:17 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Head Volumn Size
Edelbrock Heads are 60cc TFS's G2 are 67cc Whats the differance Thanks
89 FORMULA 350 Edelbrock Cat-Back March Pulleys
Accel Cap ,Super Coil SLP Airfoil K&N Filter 180 stat , Fan Switch
Taylor 8mm Spiral Pro,TB Bypass ,Energy Sus bushings ,Hotchkis STB ,MSD 6AL ,Edelbrock TES's ,Hi Flo Cat ,Crane AFPR ,1/4 time 14.4@98
Old Jul 31, 2000 | 11:33 PM
Vader's Avatar
Uhmm, 7CCs? Is that right?
The difference is that the smaller chambers will cause a higher static compression ratio and higher compression pressure. 60 CC chambers on an otherwise stock 350 with flat-tops will yield a compression ratio close to 10:1, depending upon deck height and gasket thickness.
Later,
Vader
"Some Body...Someone"
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
