Somethings melting, eek
Old May 14, 2003 | 03:32 PM
Cold Dark Shado's Avatar
Car: '86 TA wrapped in '84 skin
Engine: 305 carbed
Axle/Gears: unknown
I went out and poped the hood on my 85 camaro and noticed that from the A/C compressor, the 2 hoses connected to it have a fresh burn spot in them and the hoses in the burn spot look melted. theres no belt or anything that could rub on them that i could see. Im stumped
Im not sure if the AC works i have check for pressure on the system and it is pressurized
Heres the pix of the spots
Old May 14, 2003 | 06:33 PM
Engine: 305 carbed
Axle/Gears: unknown
I went out there again and wiped away some of the oily mess and the lines look to be fine but the oil is like thick grease or something???
Old May 15, 2003 | 08:18 AM
Vader's Avatar
CDS,
Where, exactly, on the hoses is the goo? Is it in line with the accessory belts, so that the belts may be slinging some goo of onto the hoses? Might it be under or near a gasketed joint?
Old May 15, 2003 | 12:40 PM
Engine: 305 carbed
Axle/Gears: unknown
The spot are across from the AC compressor
Old May 15, 2003 | 12:45 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Things like that make me wonder why GM didn't extend the a/c compressor's oil splash shield further, to curve around the side of the compressor.
db057
Apr 28, 2019 07:45 AM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
bryaniskoo
Oct 1, 2015 03:18 PM
corey8084
Sep 17, 2015 02:56 PM
