how can i test my hatch motor?
Old May 14, 2003 | 06:37 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
i suspect my hatch pull down motor to be bad but im not sure how to test it.. anybody know or have a wiring diagram so i can figure it out?
Old May 15, 2003 | 05:36 AM
ede's Avatar
ede
run a couple of jumpers from a 12v source to it
Old May 15, 2003 | 10:40 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What's actually bad? If the metal motor gear stripped the plastic "raise/lower" worm gear, the motor spins itself into oblivion, and dies. I think lonsol (do a search) sells replacement motors. Got mine from a junkyard. Remember to mark the alignment of the pull-down's bolts to the car. Use a scribe or awl (or white out, even!) to get a mark of the screws as they go into the car's body. Mis-align your hatch motor down too far and you strain the motor. Mis-align it too far upward and you can get leaks. Use the marks as a guide when you install the new unit.
My fiance had an '87 camaro; before I met her, the pull-down died. They replaced it with a manual non-pull-down latch from an 82-85 f-body; so it Will bolt in.
Street Lethal
Apr 30, 2019 12:14 PM
Mickeyruder
Sep 2, 2015 02:45 PM
zayne0
Aug 24, 2015 07:22 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
