Getting 5 speed pedal setup from a junkyard what all should i take?
Old May 15, 2003 | 11:52 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I just found a 5 speed t/a sitting in a local you-pick-it place and it has a 5 speed setup in it.. what all should i take besides just the clutch and brake pedal? do they come off togather as an assembly? also what tools should i bring to remove em? the guy told me i can take whatever i need for 15 bucks so i wanna make sure i get everything i can thanks guys!!!!!
Old May 15, 2003 | 02:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They all come off as an assembly.... you'll need enough stuff to drop the steering column (probably not necessary, but helpful for working space); 13mm for the nuts on the clutch master cyl U-bolt; 15mm for the 4 brake booster nuts, which also hold on the bracket; and the usual nutdrivers, picks, phillips, needlenose etc. If you can get the hydraulic assy, that'd be good, since the whole thing (both cyls, line, reservoir) can be snarfed as a unit. Pay attention to the safety switch wiring so you know what to look for in your own car.
Old May 15, 2003 | 04:53 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I can tell you that it is a pain in the *** to do.
Might want to pull out the seat if it is still there so you can lie flat on your back and do it.
You can take the pedals off first to get some clearance and then remove the main bracket. column has to come down a bit to get the bracket off. Take the switches too that are on the clutch and brake assembly.
1992 Trans Am
May 10, 2023 07:19 PM
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
