late model valve covers/roller rocker ???
Old Aug 1, 2000 | 02:33 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
What is mods are needed on centre bolt valve covers to fit full roller rockers under them?
Remove drip rails? Remove support bars? Grinding? Thanks.
92Z28
89GTA
Old Aug 1, 2000 | 08:23 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
If your getting the Crane Golds, I didn't have to do any modification to my covers.
1985 ASCD Ram Air Trans Am
http://www.execpc.com/~karpsta/home.html
to find out more
Proud member of Icon Motorsports
Old Aug 1, 2000 | 08:26 AM
GndPrx's Avatar
I ran across an article yesterday that said something to the effect that small blocks 1990 and up are ready for roller rocker/cam setups as is with little to no modification.
Please correct me if I'm wrong because I am looking to do the same upgrade.
GndPrx
http://caraudio.dynip.com
Old Aug 1, 2000 | 09:07 AM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Hey Acceld Z, just did that mod to my valvecovers about 2-months ago, I got the info from GMHTP and I also emailed Johnny H.
Basically all you have to do is use a grinder and remove that LIP on the support straps for the CENTERBOLT guides. The GMHTP mag with Johnny's 396 build up has a good picture of it. You can also email Johnny and get the info directly. HTH's
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Old Aug 1, 2000 | 11:18 AM
Hank Brote's Avatar
That's correct just the lips. Don't remove the supports or the "X" braces. I did the same thing for Comp Cams Pro Magnum rollers.
Hank
87'IROC Z28
GTAman
Jul 3, 2024 07:29 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
TheTraut88
Sep 7, 2015 05:22 PM
86iroczwv
Sep 3, 2015 06:21 PM
