383 Budget
Old Aug 1, 2000 | 10:14 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
383 Budget
Hey guys i'm planning on spending about 10K on my GTA next year when i'm done school. I am going with a 383 a probuilt 700R4 and some other stuff. I was figuring 4K for the motor. I'm thinking superram intake. I'll be building the engine with my uncle...no crate motor. I want around 400-450 HP with this motor. Is 4K a good estimate or am i WAY off? Thanks guys!!
89 GTA 350 TPI(L-98)Fiberglass "Daytona Turbo" hood the all mighty K&N filter air foil Stage 2 Fastchip(great chip!) B&M Stage 2 shift kit Flowtech(hey they work fine) shorty headers SLP 3'' stainless steel cat-back exaust Crane Cams HI-6S igntion with PS-91 coil MacEwen white gauge overlay's SLP rear sway bar Koni's all around and one kick *** stereo! Ported plenum and SLP runners are waiting to be installed.
You can see a pic of it by going here:
http://www.hometown.aol.com/clarkemustgonow
Old Aug 1, 2000 | 10:32 AM
Doug2's Avatar
With $4000 you should be able to build one HELL-of-a 383!!!! Hell, even if you wanted to go with all FORGED parts (4340 forged crank, H-beam rods, JE pistons)..
Old Aug 1, 2000 | 01:24 PM
Polecat's Avatar
True, $4000 should go a long way. Be sure to have the 700R4 build up to handle that torque too.
Good luck!
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Edelbrock 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
