sensor pipe plug
Old May 17, 2003 | 12:43 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
sensor pipe plug
trying to add a sensor to turn my electric fans on, cant get this plug to come out what is the right tool to remove it, no allen wrenches fit it metric or standard, it almost looks like it's a square fitting, what else can be used, or can I relocate the sensor to a T fitting and use the drivers side hole where the temp sensor is. I have tpi so there no place to stick it in the manifold and my radiator has no fittings either ...... gimme some idea's guys
Old May 17, 2003 | 04:58 AM
Vader's Avatar
Try the end of a standard ratchet or extension. They usually fit pretty well.
Old May 17, 2003 | 07:10 AM
Jproz1167's Avatar
vader
tried that but its a little smaller than a 3/8 th's ratchet
Old May 17, 2003 | 07:42 AM
ede's Avatar
ede
i have a set of pipe plug sockets from snap on, don't recall all the sizes, but look into gettting a 5/16" or so sized one if 3/8ths doesn't work.
anesthes
Aug 24, 2015 08:18 PM
Bert87
Aug 23, 2015 03:50 PM
db057
Aug 22, 2015 08:17 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
