Distributor problem ('90 305 TPI)
Old May 18, 2003 | 04:19 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Crap... Well I went to replace my car and rotor. No big deal... Except the rotor wouldn't budge. It must've been on there for years. I eventually got it off with use of a prybar and a spark plug socket for a pivot point, but I managed to break the eight pointed sprocket directly underneath the rotor (not sure what it's called, part of the pick-up coil?) in the process. It's broken in two places and a chunk came out. Alright, now what do I do? Can this part be replaced? What are the odds that JB Weld would hold?
I guess I should've stopped working on the car after I punched a hole in my fingernail while loosening the thermostat housing. Anyone who has done that knows how much that hurts...
Old May 18, 2003 | 04:41 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
It's called a "Reluctor", don't recall if it's bolted down or pressed in. Don't think I'd try JB weld for that.
Old May 18, 2003 | 05:23 PM
SBlackfoot's Avatar
Engine: LB9
Axle/Gears: 2.73's
So what should I do with it?
Old May 18, 2003 | 07:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You'll have to replace it. It's magnetic, and epoxy (being non-magnetic) will keep it from doing its job. It will require removal and disassembly of the distributor.
You might want to just get a whole new dist.
Old May 18, 2003 | 08:06 PM
SBlackfoot's Avatar
Engine: LB9
Axle/Gears: 2.73's
Thanks for the replies guys, even if it wasn't what I wanted to hear...
Oh well, so much for getting it e-tested this Wednesday.
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
