Help me pick some springs
Old May 18, 2003 | 08:40 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Ok, here's what going on. I'm ordering some heads from www.proshaver.com tommorrow and need to decide what valve/spring kit to order.
K1 is listed as "Hydraulic"
K2 is listed as "Flat Tappet"
Now I'm assuming "Hydraulic" mean hydraulic flat tappet and "Flat Tappet" means solid flat tappet cause the K2 springs are a little stiffer. Now here is where my question starts to come in.
The K1 springs list 110# pressure @ 1.800 (seat) but don't list the open pressure, but list a max lift of .550
The K2 springs list 135# pressure @ 1.800 (seat) and 320# pressure @ 1.200 (open) and list a max lift of .600
Ok, for some background info, I'm gonna be running a hydraulic flat tappet, and I've read that the max recommened open pressure on them is right around 300# so not to over wear the lobes, lifters, and pushrods. So, if I ended up getting the K2 kit, the 320# is listed at the max spring lift (.600) but I only plan on running a max of around .510 lift. So theroretically, my vavle train wouldn't even see 320# pressure at all would it? Probably real close to 300# I'm guessing?
I'm probably gonna ask the guy these questions anyway but I just thought I'd get some input going in. Any info or suggestions would be great.
Tom
Old May 18, 2003 | 08:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Use the K2.
Always put in the most spring that will fit. You can never have too much (well, almost never). More will simply control the valves better.
You'll end up with about 275-280 open pressure with the "bigger" spring which is fine.
pjsparts
Oct 29, 2025 06:39 PM
dbrochard
Oct 3, 2015 12:43 PM
crzycamaro86
Sep 12, 2015 05:51 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
lakeffect2
Sep 7, 2015 03:52 PM
