My 88TA has an issue! Any ideas here what it could be??
Old Aug 1, 2000 | 08:08 PM
NewYorker's Avatar
Ok, I was getting a code 43 which is the knock sensor. It was picking up the knocking of my broken smog pump. SO, I replace the pump with help from Wraith and CDartz (Thanks guys!) and the new one is squeaking a little bit. It says on the directions that it has to break in and may squeal a bit.
Well after it warms up, there are no noises whatsoever. But if I get it up to highway speed and even slightly get on the car, the light comes back on and retards the timing all over again.
I tried to pull the fuse of the ECM to clear the codes and put it back in, but it comes back after a short time.
Any suggestions here?
BTW, the knock sensor is new, the distributor is new, the computer is for the 350TBI and the engine is NEW.
Sherry
"Only in our minds can we make a heaven of hell and a hell of heaven."
[This message has been edited by NewYorker (edited August 01, 2000).]
Old Aug 1, 2000 | 08:11 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Ummmm did ya change the knock sensor toa 350 one when Rich did the sawp fer ya.. Also did ya get a custom chip burnt yet??
Kat
90 RS TBI 305 A4
My so called mods
one offically slow car
The **** poor member of the Infamous North East Crew
Old Aug 1, 2000 | 08:16 PM
Voyager Project's Avatar
Change your nock sensor, to check it tap on the passanger side tail pipe, if the computer retard the timing then it should be fine, but if it doesn't do that then it is bad, it may also be a short in the wire going to the ECM.
Old Aug 1, 2000 | 08:34 PM
Macgyver's Avatar
Sherry, we got the Knock sensor for a 92Chevy truck in your car, Jaymie and I both assumed it would work, mostly me actually. Maybe try running the Knock sensor for the Caprice Cop car your chip is for.
Damn, been to long, I can't remember what year your chip was burned for..
Fronzizzle
Mar 18, 2019 08:29 PM
mdtoren
Aug 23, 2015 12:52 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
mdtoren
Aug 16, 2015 05:45 PM
86Base
Aug 8, 2015 01:34 PM
