Electric Fans Wont't Turn On.
Old Aug 1, 2000 | 09:44 PM
big pun's Avatar
I have a 91 Camaro Z28 with a 305 tpiand it has the duel fan setup. They are not kicking on. What could my problem be.
Please Help!
Old Aug 1, 2000 | 09:52 PM
JP84ZROC
Guest
Posts: n/a
Need to find out if they come on with the a/c. Also check the fan relay and connector, and the switch(if you have one) in the passenger side head. Still no luck? Try hooking them up directly to be sure the motor/motors have not gone bad, although I do not believe this would be the case if they both fail to come on......
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
RazorN8
Jan 7, 2022 11:44 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
86IROC112
Aug 17, 2015 02:00 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
