lt1 injectors?? what rate are these?
Old May 21, 2003 | 12:08 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i bought a set of used lt1 injectors and question what lb/hr rate they are. the numberon the injector body is 17121068. i would like to know before i tear apart my tpi.(what a pita.) can anyone with injector knowledge please help. i've searched and searched to no avail. thanks.
Old May 21, 2003 | 02:46 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
If they're from a stock LT1, I believe that they're supposed to be 24 lb./hr. Don't quote me on that, though--I'm not an LT1 expert.
Old May 21, 2003 | 10:01 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
they are 24lb
Old May 22, 2003 | 09:15 AM
Vader's Avatar
If you want to know the EXACT flow (not the rated flow) and want to make sure they all flow the same, send off a note to Rich at Cruzin' Performance. For a paltry $11 each, the set will be returned cleaned, flow-matched, and have good 'O' rings, caps, and clips.
Old May 23, 2003 | 01:59 PM
Car: 1988 IROC-Z
the set i recieved were guranteed and good working order. pulled off a good running 97' Z(upgraded to larger injectors). i did put them in and them worked great. even with changing the prom settings at first the computer has a slight floating idle. then adjusted and worked normally. thanks again.
i will send off the next two sets i'm getting in to rich. thanks alot guys.
Old Sep 17, 2003 | 12:56 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
I have a set of injectors with the same number but on a couple websites it says they are 21.1#, can anyone verify for sure what they are? What's your source? Anyone know a way to contact Rochester to try to ask them directly?
New2Chevy
Sep 28, 2015 12:35 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
84 TA NV
Sep 6, 2015 08:02 PM
L0tuS
Sep 4, 2015 11:16 PM
