exhaust smell and timming
Old Sep 15, 2003 | 02:10 AM
DreamState21x's Avatar
My exhuast has a weird smell to it and my friend said he really noticed it the other day when I flew by him at WOT. Could it be running rich and should I adjust the timming.. Here are the mods if you think they could be making it run rich. and the AFPR is set at 47psi.. Thanks
Old Sep 15, 2003 | 07:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it smells rich, it probably is.
Timing has nothing to do with how much fuel is getting dumped in. Leave it alone.
Try backing off the fuel pressure. Tune it for best mph.
Old Sep 15, 2003 | 04:38 PM
no track
We don't have a track around here so I took it down the road and went from a dead stop to a sign, at 42 it seemed to be slower at low RPM but had the same speed f 95 at the sign as 47PSI. Still had the same smell. I was thinking adjust the timming because of the extra fuel it seems to be getting. I don't know that much about timming and the effect it has( as far as advance and retard go)
Old Sep 15, 2003 | 09:09 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: no track
I don't think it's the timing.... as far as unburned fuel in the combustion chamber's. But by browsing through you're mod's to the engine. I noticed you didn't upgrade the ignition system.
You're stock ignition system (if you're still running it), cannot keep up with those mod's....
Old Sep 15, 2003 | 10:17 PM
ignition
accel cap and rotor, msd coil,bosh platinum plugs, and good wires have been added. I just didn't put that in the list yet.
Old Sep 16, 2003 | 07:42 AM
Re: ignition
Then RB is right. It sounds like you're fuel pressure is too high. What kind of Fuel Pressure Gauge are you using to determine pressure?
The cheaper ones don't give an accurate reading, as when I switched from TPI to Carb, my gauge used to 'spike' causing me to think the fuel system was faulty.... when indeed it was the gauge.
Old Sep 16, 2003 | 09:56 PM
don't know
I don't remember, it was the best one I could find at autozone.. think it was like $50
Old Sep 16, 2003 | 10:01 PM
Re: don't know
Is the exhaust giving any color? Or is it just the scent of unburned fuel? Try advancing the distributor a little bit just to see if it helps any....
Old Sep 17, 2003 | 11:02 AM
Steve89GTA's Avatar
Advancing the distributor is turning it counter-clockwise...correct?
Old Sep 17, 2003 | 12:57 PM
stupid question
Ok my stupid question of the month is, where is the distributor hold down bolt.. Ive rebuilt entire engines but never messed around with timming, I know how just never dun it and not sure where the bolt is..
Old Sep 17, 2003 | 12:59 PM
Steve89GTA's Avatar
At the base of the distributor where it meets the intake manifold. It has a C-clamp looking piece of metal that holds the distributor in place with one nut.
Twin_Turbo
Mar 14, 2016 10:10 PM
timonator
Sep 17, 2015 06:57 PM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
SG91camaro
Sep 5, 2015 10:27 PM
