Backfire!!! @ 1400 rpm
Old May 21, 2003 | 12:09 PM
TBIfly's Avatar
91 RS 305
The only work I've done on this car recently is replacing the muffler. Its not completely welded on yet because a friend was doing it with a droplight and missed a spot.
It started backfiring i think a few days after the muffler swap, which could be mere coincidence.
The backfire happens in all gears at around 1400 rpms under moderate to low acceleration. 1st does it EVERYTIME when i punch it off the line...it pops and hesitates...jerking my body...then it comes back to life. I have not looked under the hood and had a friend locate it for me.
Any recommendations? What would cause a backfire?
I've also noticed that at the front side of the of throttle body is oil seepage. It seems to come from the TBI's bolts and/or the post that the air cleaner secures to. Oil residue surrounds the front side of the 2 plenums and seeps under the spacer....any insight?
Old May 21, 2003 | 12:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Lean
Put a new fuel filter in it
Old May 21, 2003 | 02:26 PM
MX265
Guest
Posts: n/a
Re: Backfire!!! @ 1400 rpm
"I've also noticed that at the front side of the of throttle body is oil seepage. It seems to come from the TBI's bolts and/or the post that the air cleaner secures to. Oil residue surrounds the front side of the 2 plenums and seeps under the spacer....any insight? [/B][/QUOTE] "
I'll second RB on the Lean condition and the need for a new fuel filter. But in your original post, (as quoted above), you documented a small leak at the base of the TBI. This leak is probably allowing air to leak into your intake and also creating a lean condition. Replace the TBI gasket and tighten it up.
Old May 29, 2003 | 06:57 PM
TBIfly's Avatar
UPDATE: replaced fuel filter............still having problems....
it seems more mechanical than anything....
i can feel it at my feet.....perhaps the marriage of the flywheel and the tranny?...im stumped.
blain
tyeo098
Nov 30, 2015 06:27 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
wisemanz28
Sep 20, 2015 01:26 PM
Racerx974
Sep 19, 2015 10:16 AM
