lt1 intake swap leaks?
Old May 23, 2003 | 08:24 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
i'm considering getting one of the lt1 intake swap setups from lt1intake.com
however, most people i've talked to say they have had leaking problems. anyone care to elaborate on this?
Old May 23, 2003 | 11:22 AM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
There have been some people having problems with the water ports at the front and rear of the heads. The LT1 intake doesn't have as much material as the older intakes do in that area. I took mine to the machine shop and had some material welded in that area. I'd let you know how it worked, but its still at the machine shop. HTH's.
Old May 23, 2003 | 03:35 PM
kevinc's Avatar
Car: 1982 Z28
Bear in mind that for some of the people doing LT1 intake swaps, this is the first time they've done it. Not likely they're as vigilant about cleanliness, torque values and sequences, etc as they should be.
I'd take the leakage complaints w/ a grain of salt...
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
sreZ28
Aug 14, 2015 07:48 PM
