HELP!
Old Sep 11, 2000 | 08:11 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
HELP!
Ok I took my car to another shop today to get another diag. on my oil leaks. They told me that it is 1) my rear intake gasket 2) oil sneding unit and 3) oil preasure switch.
My question is, I have done a search on oil sending unit and some say these car have them and others say they dont. I have changed the one under that car right by the oil filter but I guess when I installed it I didnt seat it very well, thats easy to change. Now what about the oil sending unit, where is it? and how difficult is that to change. Last I guess Im going to attempt the intake gasket myself, boy I sure hope I dont screw it up. While I have everything off Im going to go ahead and put in a AFPR ,and probably buy one of those already ported Plenums from TPIS. Clean my runners and intake up and install some Chevy Bowtie Rocker Covers. also should I go ahead and change every gaasket that comes with the kit
wishmister@yahoo.com
1987 White IROC-Z
305 TPI LB9
700-R4 auto tranny
87,000 miles
Very Clean car
Performance Resource Chip
Flowmaster Muffler
Throttle Body Coolant bypass
TPIP air Foil
K&N's
Gutted air box
Accel 8.0 plug wires
Moroso Super Coil
Blue Streak Cap and Rotor
AC Delco Rapidfire plugs
Mobil 1 15/50 Synthetic motor oil
Mobil 1 synthetic Trans fluid.
Old Sep 11, 2000 | 08:27 PM
ede's Avatar
ede
there is a sender above the oil filter and another near the distributor. both are 1/8 pipe threads, use some sort of sealer on them,i like teflon, and tighten them up.
Old Sep 11, 2000 | 08:41 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
The sender for the gauge is o nthe back of the intake, damn near under the distributor. It is a pain to get at without removign the distributor. I would try to seal it, then do the intake.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Old Sep 11, 2000 | 09:25 PM
glad to have help like this, is a ported plenum really good for some power even with maching the runners and intake....I want to polish or paint my runner, intake and plenum,,,what do you guys think?
1987 White IROC-Z
305 TPI LB9
700-R4 auto tranny
87,000 miles
Very Clean car
Flowmaster Muffler
TPIP air Foil
K&N's
Gutted air box
Moroso Super Coil
