Quick Question - Wheel Torque Specs
Old May 25, 2003 | 02:03 AM
Trevor K's Avatar
I have aftermarket 16x8 aluminum wheels - should I be torqueing them to 100 ft/lbs?
Old May 25, 2003 | 02:10 AM
Kandied91z's Avatar
need to check the specs with the wheel company. i know my stock aluminum wheels were at 100 however my new aluminum wheels are at 85.
i have to torque the adapters to 100 since that's the recomendation with the hub but i can't exceed 85 on the wheel.
Old May 25, 2003 | 02:22 AM
Trevor K's Avatar
They're just Eagle Alloy wheels....I guess I have to call them then?
Old May 25, 2003 | 03:14 AM
Kandied91z's Avatar
i'd call them to be sure but it will probably be the same as the stock specs which as far as i'm aware is 100
Old May 25, 2003 | 03:59 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
75 to 100 is usually the going rate, so somewhere in there .
100 sounds about right to me, but don't quote me on it.
Old May 25, 2003 | 05:46 AM
ede's Avatar
ede
my weld pro stars are 65 ft/lbs, so all wheels don't require the same torque
Old May 25, 2003 | 07:30 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
In the owner 's manual the torque spec is 85 #/ft for the Aluminum 16 x 8 or any other of the same type. Too much toque may cause stress cracks or make removing the lugnuts difficult.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
TreDeClaw
Jun 22, 2021 08:21 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
