cold start problem
Old May 25, 2003 | 08:34 AM
RichSoucie's Avatar
cold start problem
my car has a problem when cold starting it takes about foru to six tries and i have to keep my foot to the floor but it doesnt rev up i can here detonation in the engine compartment and after about 10 seconds it revs up and i put it in gear and it just creaps along and i here detonation in the engine compartment after about ten minutes of driving i am good to go. I am getting a code 15 and code 44 i just changed the o2 sensor didnt fix my problem
Old May 25, 2003 | 09:34 AM
Vader's Avatar
Rich,
The '15' is for a coolant temperature sensor circuit fault. Check the connector at the sensor, and test the sensor resistance. The ECM depends heavily on a CTS reading for accurate mixture control and starting.
Incidentally, starting a GM EFI engine with the accelreator fully depressed cuts off all injector pulses (delivering no tarting fuel) since a high TPS reading during cranking invokes the "Clear Flood" mode. Unless you have a flooded engine, it isn't advisable.
Old May 25, 2003 | 09:35 AM
RichSoucie's Avatar
it starts up and starts to die that is when i put my foot on the gas
Old May 25, 2003 | 01:25 PM
Vader's Avatar
Roger that. Check into the CTS circuit. It may be crucial.
92camaroJoe
Jul 29, 2023 07:57 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
