30# Injectors too much?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I'd say yes... You only need 30lbs if you're running a blower or nitrous. Try 24lbs.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 2006 Silverado 1500
Engine: 5.3L
30lb injectors may be a bit big for it, but it leaves room for adding more. don't expect to run them without a custom chip though. be too rich otherwise. require some tuning too, but they can be made to work.
Transmission: 4L80E/4L80E
If you expect to drive this thing on the street, you'll be quite disappointed with 30#-ers. 22's would be adequate for a street/strip engine, 24's would only be required for a totally tweaked setup.
Adjustable regulator and chip a must.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 3.08 open, cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, World 305 heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
thejimsterz28
Sep 15, 2015 04:37 PM
