Question about the rods..
Old May 28, 2003 | 01:19 PM
AFast83z28's Avatar
is there any way to look at the h-beams and the i-beams and tell which is which? or is there any way to tell if you have the h-beams? also...one of the rods has avery very very small hole in the "cap" (where it hooks to the crankshaft).it is black and very hard to see. it's not deep. you can run your finger over it and feel it. what will it take to fix that? about how much will it cost to fix that?
Old May 28, 2003 | 05:51 PM
Damon's Avatar
Yes. Describing it may be a little tough. I'll give it a try.
Stock rods are I-beam style rods. Single main rib running up the center of the rod (points side-to-side as installed in the engine) with the little "wings" on the ends of it pointing front to back as installed in the engine.
H-beams have 2 ribs running up the sides of the rods, pointing side-to-side as installed in the engine, with the center "connector" part between them pointing front-to-back as installed in the engine.
A good picture would be worth a thousand words here. Maybe someone could oblige...
Old May 28, 2003 | 05:55 PM
AFast83z28's Avatar
I think I understand. If you are laying a h-beam flat on the ground it looks flat. then if you look at the side view it sinks in and has two "lines" i guess you could say. if i can find a camera i willl take apic
Old May 28, 2003 | 07:48 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
I beam
Car: 87 Firebird
H beam
Old May 28, 2003 | 10:38 PM
AFast83z28's Avatar
sweet...I have an h-beam!!!!!!!
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
