Put on an air foil... thru a code
Old Sep 12, 2000 | 06:39 PM
Fat Elvis Z-28's Avatar
Has this happened to anyone else? I don't know what the code is yet, but it never thru one untill the day I put it on
Old Sep 13, 2000 | 02:20 AM
Ski89Z28's Avatar
do you have a MAF?
If so did you unplug it to put in the air foil? If so did you plug it in again?
Old Sep 13, 2000 | 09:28 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
never had that yet, but questioning it does no good. fixing it does. what code has it stored???
Old Sep 14, 2000 | 06:36 AM
Roy's Avatar
Roy
I doubt your airfoil was the cause of the code. Unless it occured during your installation I think you are going to find the two are unrelated.
Roy
Old Sep 14, 2000 | 07:15 AM
OK this will be my first code pull and I'm not totallly sure of the process. I have a good Idea but If some one could walk me thru it a little that woulb helpful
I drive a 91 Z-28 LB9 Thanks for the help.
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
