Hvac controls screw with idle?
Old May 28, 2003 | 11:38 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
i noticed on my car that when the Hvac controls are on the last option (window defrost) it makes the engine run really different then anny of the other controls. is there any reason for this? i thought it was kind of odd...
Old May 28, 2003 | 11:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You may have a vacuum leak that goes away when in defrost. Or, it may be the AC compressor kicking in in defrost mode.
Old May 29, 2003 | 12:44 AM
Slackett's Avatar
Fivekid.............
"...compressor kicking in in defrost mode..."
Mine does that! What the heck causes that?
Old May 29, 2003 | 11:08 AM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
the a/c compressor is turning on causing a strain on the motor for a few seconds,. thats why the idle goes down for a few second then should jump back to normal. the a/c compressor turns on when you turn on defrost because the cold air defogs the window faster than warm air.
if im wrong on that stuff someone correct me, but i believe it to be right
Old May 29, 2003 | 11:32 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the AC should turn on to remove moisture from the air.
Old May 29, 2003 | 03:42 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Well, the compressor on GM cars of this vintage definitely kicks on in defrost mode. But it isn't because cold air defrosts better--it defrosts WORSE, usually. It's because the A/C also has the side effect of dehumidifying the air.
On a VW we have you have to manually turn the A/C on in defrost mode. Surprise, the best defrost is usually with the temp lever centered (if it's warm out, I can't take hot air blowing out the vents at me when it's 85* and rainy) or full hot (if it's cold out) and the A/C switch on.
Old May 29, 2003 | 06:13 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That's funny; I thought the A/C clutch cycled on to keep the compressor "alive" during the cold months. My a/c's been pulled out for years, the windows still defrost fine. Never gave it a second thought!
Er; wait a min. When the heater door is swung to "hot", air doesn't go over the evaporator coil. Does it?
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
db057
Sep 4, 2015 07:57 AM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
