What causes blow by?
Old May 29, 2003 | 12:07 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
What exactly causes this, because i put an oil breater on my car, and there is blue smoke that comes out of it constantly, and how do i fix this.
thanks
Old May 29, 2003 | 12:42 AM
Slackett's Avatar
Majority of the time......rings.
But could be other things depending on your engines health.
Cracked head (from overheats)
Valve seals
Valves not seating well (carbon)
Old May 29, 2003 | 05:19 AM
ede's Avatar
ede
insuffecient seal between the piston, rings, and cylinder wall. any valve related problems won't cause blow by.
Old May 29, 2003 | 03:21 PM
rezinn's Avatar
Sounds like you need to take the breather off and put the stock setup back on.
blackz281le
Jan 11, 2016 07:51 AM
Fanatic1074
Oct 2, 2015 03:47 PM
86IROC112
Sep 28, 2015 08:17 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
90formulaVortec
Sep 3, 2015 09:26 AM
