Where would you shift my combo?
Old May 29, 2003 | 02:41 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
My combo is a 10.6:1 355, hotcam(218/228 .525 I/E), aluminum L98s, HSR, 700r4, 3.27.....
Where you you shift this combo? I currently shift 1-2 at 6000rpm and 2-3 6400 but would like to hear your input.
Old May 29, 2003 | 03:44 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I would think the HSR can rev higher than that. As a rule of thumb you are suppose to shift about 10% RPMs past your peak HP.
If there is a dyno in your area I would suggest taking your car there.
Old Jun 5, 2003 | 02:33 AM
mastrdrver's Avatar
You should shift so that your avg. hp #s are your highest over the range which your engine drops its rpm. I think that cam will peak in the 5800-6200 range. I know of that the LT1 guys are shifting in that range on stock heads and bolt ons.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
