burnout, and now a metal cling noise
Old May 30, 2003 | 10:07 AM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
i just did a donut in a parking lot, and as i was driving away, it sounded like i was dragging something metal, so i go to check it out, and there is nothing hanging underneath my car... what coudl it be? it won't go away....
Old May 30, 2003 | 10:12 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Drain and ispect your rear end. Could be the posi unit. Or, you can put the rear on jackstands and let the motor turn the rear wheels, just be extremely carefull when doing this. Best to do this on a lift if possible.
Old May 30, 2003 | 10:15 AM
Dingley's Avatar
Engine: LG4 305
i don't have posi, i got a one-wheel wonder
could the rear end still be the problem
Old May 30, 2003 | 10:17 AM
Zepher's Avatar
Yeah, It could be the rear. I would inspect it and change the fluid.
Also, check the brakes as well. something might have gotten loose and is rubbing.
Old May 30, 2003 | 12:12 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Yeah I'd check brakes....
Old May 30, 2003 | 12:15 PM
Dan88IrocZ's Avatar
Burnouts aren't so cool anymore are they?
Old May 30, 2003 | 01:03 PM
FyreLance's Avatar
I disagree.
Old May 30, 2003 | 01:36 PM
copperhead110's Avatar
I would suspect the exhaust is rattling or running something.
I've only heard one rear end that was going out and it sounded more like a jet engine whining.
If you have after market wheels w/ metal center caps, check them. I had a set of wheels w/ a lose center cap. It sounded like I was dragging a chain. I'd stop and look under the car and there would be nothing there. When the center cap finally fell off the problem went away. Unfortunately, I was short 1 center cap.
You might want to drive by a buddy and see if he can pin point the source. I doubt that will work well though.
Or go try to get on www.darwinawards.com. Strap someone to the bottom of the car and drive around. If they die, you'll get a Darwin Award! That actually happened. A guy was strapped to the bottom of a 4x4 looking for a rattle and got killed when he got wrapped around the drive shaft.
I hope this long post was entertaining or informative.
Good luck
Old May 30, 2003 | 01:40 PM
If you put the car on jack stands and put it in gear. DON"T DO THAT ALONE. You will definitely want someone in the car and I wouldn't get under the car at all.
Without any resistance the wheels will spin pretty fast and any imbalance of the tires will show up. You certainly don't want the car vibrating itself of the stands.
Old May 30, 2003 | 01:52 PM
Dingley's Avatar
Engine: LG4 305
well, i drove by a friend, and he said he coudl see something dragging on the ground towards the middle of the car.... and it goes away, and comes back , especially when i'm driving down hills, does this help?
Old May 30, 2003 | 03:04 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Maybe the front of the torque arm or its mount broke? It kinda makes sense since you just got done doing donuts and the torque arm front mount takes a lot of stress.
Old May 30, 2003 | 03:17 PM
It might be a good idea for you to get that fixed before you drive around anymore.
I agree that the torque arm may be the problem.
If it is, I think it might be able to hang down and catch on something. If that happens you'll cause some major damage to something.
Let us know what you find.
Old May 30, 2003 | 06:05 PM
Zepher's Avatar
If the torque arm was broken, wouldn't it bang on the bottom of the car?
I am thinking e-brake cables or bracket.
Does your e-brake work?
Old May 31, 2003 | 10:22 AM
Dingley's Avatar
Engine: LG4 305
ebrake does not work, but i don't know if it ever did, i never use it.
Old Jun 1, 2003 | 04:26 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
how about you crawl under the car and have a look? it's better than all of us guessing
Old Jun 1, 2003 | 07:20 PM
Dingley's Avatar
Engine: LG4 305
i did, and there's nothign noticeable
Old Jun 1, 2003 | 08:42 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Loose torque arm? I've heard of them coming loose under huge loads like a burnout if the bolts arent tightened enough.
Old Jun 1, 2003 | 09:08 PM
Dingley's Avatar
Engine: LG4 305
i'm not the mechanic i'd like to be (yet!)_.. so, can you help by telling me where the torque arm is located? thanks. a picture would be very nice.
Old Jun 1, 2003 | 09:24 PM
The torque arm is connected to the rear end and the transmission or the cross member holding up the transmission.
Its job is to keep the front of the rear end from twisting up under heavy loads or acceleration.
Hear is what a fancy lightweight one looks like from www.lgmotorsports.com ( a picture is supposed to be attached)
http://www.lgmotorsports.com/OCLS1_Fbody_Suspension.htm
This torque are is similar. The stock one is stamped steal.(I believe
I'm going to have to agree w/ Ukraine Train. You need the car up on 4 jackstands and look and wiggle things to figure out whats loose and hangin' done.
Good luck
File Type: bmp
Old Jun 1, 2003 | 09:56 PM
FyreLance's Avatar
I don't think so... the torque arm is going to be loaded by the rear suspension. If something broke it would shoot up and rest against the floor pan. I don't think anything would make it come down far enough to bang back up against the top of the car unless he's doing hill jumping. I could be wrong though.
Thirdgen89GTA
Apr 11, 2016 02:07 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Numbah-1
Oct 2, 2015 08:27 AM
sjorgens
Oct 1, 2015 07:54 PM
