vortec head help
Old Jun 1, 2003 | 10:16 PM
Killogy's Avatar
Car: 87 Firebird Formula
Engine: 355
vortec head help
I just got a set of 906 casting vortec heads. Do I need to have them machined to fit springs that will take my lift? Or can I just put in springs that are the same diameter? Also, should i change valves and rockers and all that or are stock ones good enough?
Old Jun 1, 2003 | 10:17 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
What kind of lift are you going to run, and what spring were you wanting to use?
Old Jun 1, 2003 | 10:19 PM
Killogy's Avatar
Engine: 355
.488 lift and I don't care what springs, as long as they work.
Old Jun 1, 2003 | 10:24 PM
Engine: 383, L69
with that kind of lift, the stock vortec springs wont be adequate, you should get some comp 981s , if i recall corectly, they are 1.25 diameter spring, the same as the stock vortecs, also you may have to have the valve guides milled down
kevin
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
