Coil wire??
Old Jun 1, 2003 | 01:01 PM
JR305's Avatar
Coil wire??
Ok, I am trying to finish the project I started a while ago and am pretty much finished. Though I was, but when I went to hook up the coil I found that I only had on of the connectors to it. I found the other on but am unsure where it goes. I have a pic, the connector on the left goes to the coil but where does the other one hook to.
Old Jun 1, 2003 | 01:13 PM
Killogy's Avatar
Car: 87 Firebird Formula
Engine: 355
I think that may be the one that goes from the coil to the distributor. I had the same problem when I swapped engines with those 3 wires.
Old Jun 1, 2003 | 01:37 PM
JR305's Avatar
Thanks for the reply.
I think you are right, I went through the wiring diagrams in the Haynes manual and I had the air temp sensor plugged into the dist . It seems I need a new temp sensor, the TPI and TBI aren’t the same. So that solves two problems.
stalkier
Dec 6, 2015 11:25 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
L98GTA87
Aug 5, 2015 11:02 PM
